frumaker
- killeen, tx
2009 H3 with Adventure package, 17x9 steelies with 33x12.50 mickey's
I have the torsion lift in the front and the rear is stock. I have added a bit of weight between the roof rack, steel wheelsand bigger spare tire. so now the back end is a bit lower. also, i hit some heavy trails and my tires tucked so far in the rear fender, the fender partially popped off. i am looking for ideas to get the back end a little higher. i am not opposed to a stiffer ride. i'm more concerned about the back at least being level with the front, even higher in the rear is fine, and i also want to make sure the tires don't pop the fenders again.
i have looked into the rear shackles, rear add aleaf, and SOA conversion. I have not been able to find constant feedback. some say the shackles can flatten the leafs and cause problems and others say it's great. i have heard some say the add a leaf actually doesn't lift the rear. as for the SOA, well...i don't know if that will put the rear too high and how hard it is for a home garage project.
also, what are the thoughts on the extended front bump stops in the front since i did the torsion lift.
any help is greatly appreciated.
