I can't say for sure but I have been running the 315 for the last 20,000 or so when I got some used on the Hutchinsons. I was a hold out for the 285 for a long time but tried these.
I have noticed some changes in how things are doing up front.
I'm going back to 285's for my winter set of tires for several reasons, mainly some long distance travel.
Here is something new I am going to try for those that have had problems.
I want to try to make this clear again, if you put 1/2 the sleeve in the bracket with it out of the vehicle, then put that in a vise and squeeze on the rounded part of the bracket you can get it to conform better to start with. I don't know how to explain that any better. I also suggested if you slightly over do that and the holes are off a bit try grinding out the lower hole as it has more bracket around it, just enough to allow you to line it up easier.
I'm going to go weld half of one 2 inch sleeeve on a bracket so I can see what that does for holding things together, as an option to grinding.
I still think squeezing, grinding, add neoprene and welding for hardcore fix along with flex lines and off center extra bracket with brace to drivers side bolt would be the culmination of all things to do the most reinforcing.
It has become obvious some people are just slapping the sleeve in there and not grinding or using the option of neoprene and that just won't cut it. The clamp has to be tight on the sleeve both with wheels on the ground and jacked up at full droop.
Got some work done.
