Tire Wear Guidance
H3Hrly
California
Hey guys. I'm curious about my tire wear, and want to be sure this doesn't happen to my new set.
Background. The H3 drifts right, more so I think it should, & more than the wife's car when driving the same roads. I've taken it to the dealer 3times in last 2months since putting on new tires. They say alignment is within specs on first two occasions; on the third visit, some minor tow settings were adjusted. Vehicle mannerisms are unchanged. Below is a picture of tire wear on original tires--this tire on front right; others were similar.
Q: what might cause this type of wear? What is done to correct it? What might be causing H3to keep drifting right (besides crown in road)? What is done to correct it?
Thanks!
imagejpeg
Scarsman
Monroe, WA
Well, there wear on there looks like what is called "cupping", which is caused by bad shocks and/or lack of rotation. Tires left on the front and never rotated to the rear will do that. It looks like there is a little more wear on the inside edge than outside, which would indcate an alignment issue.
As for the pull you currently have, the first suspect is alignment, which you seem to have elliminated. (providing yo have a decent alignment tech) So if that is fine there could be a couple other things to consider. Sometimes a tire can have a "radial pull." This is caused by a defect in the way the plys are layed in the tire. To check this you can switch the front two tires side to side. If this was the problem then the pull will either go away or pull the other way.
Another possibility is how the alignment was done. Many alignment techs will actually set things slightly "off" on purpose to compensate for the crown in the road. Pretty common practice. If your guy actually set things "dead on center" then you would end up with it drifting to the right from the crown. If you drive in the left lane, (opposite crown) like passing, does it still want to drift right?
First thing I would do is swap the two front tires and see what happens.
I think the H3 is a little more affected by the crown of the road than my other cars, even when properly aligned. Some degree of your pulling may not necessarily be a problem, but just a characteristic of the truck.
I would agree, steering wheel turning amount is unusual on the roads.
H3Hrly
California
Thanks y'all for ur inputs! I've quite religious about rotating my tires around 5-7k miles. The pull is there even when I drive in the left lane. Looks like next step is to follow Scarsman's advice and swap front two tires. And also ill check the shocks.
