H3 and other items for sale
60" High Lift Jack - $50.00 (prefer not to ship due to weight and length)
Front drive axle - factory - $70.00 (SOLD)
Inner tie rod - 16mm - $30.00 (SOLD)
Outer tie rod - 16mm - $35.00 (SOLD)
Both tie rods - $60.00
6-Disc CD Player - used for about two weeks - $100.00 (will need to have the bit reset to accept another VIN number to allow it to work in another H3. Dealer can do it with a Tech 2) NO LONGER FOR SALE....
Pull pal - GVW Weight Under 6000 lbs (so not for H2/H1) Frame was repainted black last year, shovel is original gray color - $200.00 (can ship, but it is heavy) (SOLD)
RAM PC mount. Do drilling install, bottom plate and pole mounts to existing front seat mount studs. PC platform is attached to another pole that slides into the base pole. $50.00 (SOLD)
I would like the Ram mount and the tie rods. Please PM me your PayPal information if its okay by you.
Is like the high lift as well but that would depend if shipping is worth the effort for you.
Sent with Tapacrack
Im a maybe on the pull pal. I wouldnt ship it, if I was to buy it would you hold on to it till april when I go to moab or do you need to get rid of it?
Doug, I'll take the CV axle shaft.
By any chance, is it a new one?
I tried PM'ing you, but your filled up. So here's the reply...
Yes, I'll hold it till you come out in the spring....no problem. Pay me then. And if you can't make it (aka pike), then we can make arrangements withsomeone else to bring back to CA.
