Actual SAMCO FARBRICATION Extended Shackles - $60 Shipped
Schwarttzy
Rockford IL
Sold
Since I decided to make every part myself on my hummer, I got some actual Samco Fabrication Extend Shackles power-coated black. Asking $45 for the shackles and $15 for shipping.
Thanks!
BIGSTUF
Nashville, TN
Sorry, but when it comes to shackles and leafs etc., I'm kind of in the dark. Do you mind explaining what the 2" shackles do? Is it a lift? And if so, I know the front can only be adjusted so much with the torsion bar, would anything else be needed? Thanks in advance...
Schwarttzy
Rockford IL
They are 2 inches longer than the factory ones, but only net you .75 inches of lift in the rear. While that isn't much, the magic is that the leaf spring has three-four inches more to move total in either direction and lets that rear axle do more work.
Also if you crank the torsion bar up and want to keep a forward rake for gas millage this will help out with that too.
