New Wheels?
Hayden
Toyo M/T
Virginia, US
Hey everybody,
First off id like to say Merry Christmas to everybody:)
Second, i was wondering if anyone that knows more about wheels than me could help. Im looking at the 16x9 XD Addicts and need some clarification on whether they would fit or not
The specs that i could find are:
Bolt Pattern: 6x139.7 (i know that fits)
Offset: -12mm
Hub Bore: 106.25" (I've hear that h3's have a 100mm hub and also heard that they have a 106mm hub)
BackSpacing: 4.53"
Pretty much what i need help on is if the offset/Backspacing and the hub will fit and will it clear all the the steering components
I really appreciate it,
Hayden
EDIT:
Here's a pic
I believe this wheel would stick out alot over stock setup, esp if you add to it a wider tire.
Stock wheel is 7.5" wide with 38mm offset. Just checked on a site and it apparently clears 31mm more from the inside but sticks out 69mm. A more positive offset on this wheel could get it to stick out less.
is350
fallbrook, Ca
Merry Christmas, i have the same wheel except in 17'' diameter in a 18 offset, and that sticks out a little over stock so -12 offset would stick out. i think those would little more then an inch past mine, make sure that you also purchase the hub centric rings
Hayden
Toyo M/T
Virginia, US
Sticks out 69mm more than stock correct? and i want a wider look so a couple inches out on each side wont kill me, as long as i can actually run it :giggle:
View attachment 8089View attachment 8090
Nice! That looks great, i think a inch past that wouldnt be too bad. Do the wheels have the same specs other than that? And what size are the hubs on the h3? because ive seen different things. Thanks :)
is350
fallbrook, Ca
yes they are the same spec except for the diameter. I'm not 100% about the hub size, but i think i read somewhere thats its 108mm
Hayden
Toyo M/T
Virginia, US
oh ok cool. Cant be 108 though or the wheels wouldnt fit on there haha :giggle: thanks though, think im gonna measure it myself to make sure anyways
If you're looking to change to a 35" tire from the stock 32", ur tires will also stick out 1" extra over stock. So you would be looking at almost 69+24 = 93mm. It could be slightly more or less.
