H3 Windshield Trim Repair - Another Solution
cbetts
NERD!!!
Rancho Palos Verdes, CA
While working on replacing my off road lights on my rack, I broke all the tabs the secure the drivers side windshield molding.
I remembered how Alrock had fixed his using nutserts but I really didn't want to drill into the metal giving an opportunity for water to enter. Upon careful inspection, I noticed the plastic inserts already in the pillar were sealed. It looked like a #8 machine screw would work perfectly.
I drilled holes where the plastic lugs were before breaking them with a drill slightly smaller than the screw to keep things tight. I also trimmed down machine screw to keep it from reaching the very bottom of the inserts.
The chrome heads look tacky. I need to go to my local hardware store and find some black head bolts to replace these.
Looks good and I'm sure that will hold up. BTW, I sealed the nutserts with RTV to minimize leaks.
Yes. And with these pics you can see where the clips are. It also hooks into the plastic on the roof that holds the roof rails.
evldave
somewhere west of north
Do you just need a flat head screw diver to remove them? What about the rest of the trim on top?
The rest of the trim on top is held in place with a bunch of torx bits down the main rail. To remove the top trim, you have to remove not only the trim, but also the roof rack rail. It's a pain, but fairly simple...
