telemike
Hummer Enthusiast
- Greensboro, NC
Thinking of replacing the dash unit on my 2007 H3. I hvae the Monsoon speakers with the 6 CD changer radio. No navigation. I know I need an adapter for the door chimes and onStar. Which adapters are best?
I also want Double DIN size, any issues with installing?
Thinking of the JVC KW-HDR720
Please Note: Your vehicle is equipped with a factory sound system that requires a special adapter to install a new car stereo. We strongly recommend that you purchase one of these adapters, and you'll save 50% if you buy it with any car stereo.
- Axxess GMOS-100 GM Factory Integration Adapter Retains satellite radio, OnStar, Bluetooth, backup camera, rear-seat DVD, warning chimes, and steering wheel controls in 2000-up GM vehicles $219.99† $109.99
- In order to retain your vehicle's warning chimes, you must use a factory integration adapter recommended by Crutchfield. Failure to do so may result in serious injury and/or death. Crutchfield cannot offer technical support for an installation undertaken without this adapter.
- This upgraded factory adapter package allows you to retain all the factory options in your GM vehicle, including warning chimes, OnStar, steering wheel audio controls, rear seat entertainment, satellite radio, Bluetooth, and factory amplifier. Any of the features requiring a display, such as satellite radio, will require either the factory Driver Information Center or an optional LCD display.
- You'll need the GMOS-100 adapter to retain your factory XM capability if you replace your factory radio. If you do not have the Driver Information Center you will need an optional LCD display.
- CRUX SOOGM-15 GM Factory Integration Adapter Lets you install a new stereo in select 2000-up GM vehicles while retaining OnStar®, warning chimes, and steering wheel controls $139.99† $69.99
- The Crutchfield harness makes the connections between your new receiver and your car's electrical system. A detailed instruction sheet comes with the Crutchfield harness.
- This upgraded factory adapter package allows you to retain your GM vehicle's warning chimes, OnStar, steering wheel controls, and Bose or Premium Bose systems.
- Metra GMOS-04 GM Factory Integration Adapter Retains OnStar® system, factory door chime, and Bose® system with aftermarket radio in select GM vehicles $99.99† $49.99
- CRUX SOCGM-17 GM Factory Integration Interface Retains the door chimes and audible warning system in select GM vehicles $59.99† $29.99
- This upgraded factory adapter package allows you to retain your GM vehicle's warning chimes. This package is not compatible with OnStar, steering wheel audio controls, or PREMIUM Bose systems.
