Wheel Speed Sensor P/N
I've been fighting an ABS/Traction Control light and did what I should have done to begin with and had the code checked. It's the left rear speed sensor. I thought (maybe incorrectly) that each position was a different GM Part Number. The chain parts stores don't even list one as available, and the GM parts lookup shows only part number 15862988. Is this the correct number for either the right or left side? (2008 H3). Thanks in advance.
The parts manual lists that part number (15862988) for both L & R side rear speed sensors.
Thanks! Where did you look that up? Is this something online that the common folk can use, or something only available to the cool kids? :huh:
Cool. Just thought Luis might have been using something more advanced. GM Partshouse, Nalley, and GM Parts Direct all have really good catalogs.
Jeremy, pm me your email address and I will send you the GM parts reference sources that I have. They have come in handy more than a few times and the parts numbers have been spot on.
