Custom front and rear bumper and sliders
hockeymanam
charlotte
hey guys so i found a company looking for a H3 to start their build of mass production front, rear bumpers and sliders. I will be gone in europe the month of may so they will have my H3 the whole month to do the build. So i get to "motivate" the design and I personally thing the ARB style is too bulky and Im a Fan of Thorparts. Any recommendations for the design or options ... THANKS:thumbs:
WillieMo
Miami, FL
I'd love to see a short bumper closely resembling the stock look without the wings but with built in winch and re-using the stock fog lamps....
MTUH3
Plymouth, MI
Simple is better. Rear bumper should wrap around and eliminate the plastic gray lower parts of the rear fender. It should also incorperate the addition of a second D ring on the rear bumper
LIGHTWEIGHT! The h3 doesn't need any more weight so a stubby bumper for the front will look appealing be lighter compared to others and give more wheel well opening from the front. Kinda like thor parts. Rear I'm not sure. Keep it light I notice that on steep climbs there's not much weight on the front tires and putting a heavy rear bumper on the back may make things worse
ArtHummer
Gaithersburg/MD
I'm with you on the bulky look for most of the bumpers and I like more of smaller designed like Thorparts or what Recon did with his build...
I was actually thinking about building my own front end and as inspiration I was looking on the original concept design of the H3T.
Also, I don't know how far you want to go with changes and cutting, but my idea was to shorten the frame to achieve higher approach angle. Here is the kind of a sketch of what I was thinking.
So, the light blue line is the rough lines of the frame. You will need to cut of where the red dotted line is. The piece that will be cut out will have holes for mounting D-rings. That piece will have to be welded on top of the frame on the place of the dark blue line. Everything will have to be reinforced allot to be able to hold the weight of the pressure that can be put on the D-Rings. From what I see there should be enought room for reinforcement to clear the body and AC lines... Then you will have to design the bumper based on the new location of the mounts... Also (the main idea of it all) design new front bumper skid plate along the red line. Since the D-ring mounting position is higher, it should give you few extra degrease to your approach angle and it will give you that aggressive look of the H3T concept's skid plate.
rsc
Tulsa
Simple is better. Rear bumper should wrap around and eliminate the plastic gray lover parts of the rear fender. It should also incorperate the addition of a second D ring on the rear bumper
Absolutely! +1000
hockeymanam
charlotte
its all free so im doing all three. and for replacing the rear side plastic pieces here is something similar done on an FJ of theirsMultiCarrier-111.JPG
hockeymanam
charlotte
yea I was very surprised but my friend found them while looking for bumpers for is toyota and they had a H3 previous but he backed out for some reason
silvrzuki77
Vegas
Been there, there are quite a few forum members who have built alot of this and offer it.
Just seems alot of spinning of the wheels. Its cool your getting it for free.
I think I can agree with the general consensus here, a shorty style front bumper with winch capability that retains the stock fogs... oh and one that incorporates a new skid plate!!
hockeymanam
charlotte
hey 4speedfunk I hope you dont think Im stepping on your toes with this post. I would prefer your bumpers but being on a college budget I would be crazy to not take this guy up on free parts even if its not perfect! :thumbs:
No sweat. I love custom stuff...and even if you start with a THORparts bumper and cut on it, grind on it, weld on it....its still a huge time saver vs. starting from scratch.
