- Tardville
Pulling the front driveshaft on an H3 doesn't gain much
True...not on a stock H3. But I'm already SA with Warn lock-outs. I just need the t-case to complete the package.
You need to increase the power and decrease weight and rolling resistance.
Find a lighter wheel and tire combo. If you're running an 18 go down to a 16. Smaller tire with a narrower footprint will help.
If you're running aluminum rims, an 18 with a tire keeping the same heights & width will be lighter than a 16 of the same. The rubber is the heavier part in truck tires.
Not true. Take a goodyear duratrac in a 35" tall tire. 315/75r16 vs 325/65r18. Both are 34.6" tall. Both are about 10.5" wide at the tread. Both weigh 64#.
The wheel is the difference.
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+DuraTrac
Another example. BFG AT. 285/75r16 vs 275/70r18. Both 33" tall and 9.2" wide. The tire for the 16" wheel is 56#. The 18 is 57#.
More wheel is more weight.
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO
Even if you do all of these things...the H3 is basically shaped like a concrete block. I don't see anyway to decrease the drag at high-way speeds. I has to be tremendous. If you really want to see some efficiency...limit your speed to 30mph.
The best bet is a larger overall tire size, but very lightweight, which makes for lower rpm and less spinning mass... Unfortunately wagon wheels won't work on an H3
Sent from Nates phone...
Ah... No.
The larger the tires diameter the more resistance to rolling it has. The further away from axle centerline the tread is the harder the motor has to work to overcome. Basic physics. Look up moment of inertia.
The motor may be revving higher but that doesn't translate directly into more consumption.
As for the tire weights. Remember, a 16" tire and an 18" tire are the same except for the 1" thick strip of rubber in the sidewall that's 'eliminated'.
Inertia= mass x radius squared.
You gotta remember smaller overall tire size will equate to higher rpm in the motor to turn the same speed on the highway..
Those wheels are awesome! Shipping to 85204?
Yeah, but breaking distances might be a tad longer than stock... :whaa:I'm willing to bet he went up a few mpg with that setup.
