- Meridian, ID
Thorparts didn't have any in stock last I spoke with him, gonna email him again as I need that driveshaft.
I think the upgrade is in october??
We shall see how reliability is on this trip. Two things that must be fixed and is a non rancho problem is the weird steering rack noise and that its starting to split after 86k miles (saw that during rancho install) and the front frame mounted axle bushing is a non rancho part and is bad. That bushing will blow an axle...luckily I had a spare in storage that I sent to preferred chassis while they make a better replacement as the bushing is not serviceable. Will throw that in before moab too.
Cg the wedge adjusts the pinion angle. This helps keep driveline angles much nicer
The only thing that pisses me off is the axle clearance...I gain all height at the rockers, bumpers and midsection but lost axle clearance. I still think a new spring pack is the best choice but even with research I never found this as a problem, I also would like clearance numbers for Hunners rear skid axle clearance with a 35...I still probably have more with the tomp skids which is a plus.
Time will tell...just like nugget, when he did lots of trial and error with turbos and superchargers for the I5 he had to change and modify things till he was happy, same goes for me...moab will tell me how much I get hung up, this may be the solution for me or may not be, but one plus for everyone else is that they can view the pros and cons before they pull the trigger on anything. Im the test dummy
