08 Alpha Cammed Transmission Upgrade?
StandoutAlpha
Minnesota
My factory 4L60e transmission on my 08 Alpha cammed just took a sh*t at 126,xxx miles. Which tranny should I replace it with? A beef up 4L60e or a 4L65e<--is that even compatible with the H3's LH8 5.3L v8? Previous owner did alot of off-roading and mudding im thinking that is why the trannys life got shorten or maybe even because of being cammed out it has to much power for the factory tranny to handle. Let me know thanks in advance...
125K is a good amount to get from a 4l60 behind a cammed 5.3L, 5500lb brick. The 4l65/70 variants are just beefed up 4l60e internally, any reputable trans shop should easily do the same setup and even better.
What tires are you running? If 35s you can regear the axles to 4.56 and that will reduce the stress on the trans and front/rear prop shaft (but move it to the outward shafts if you have a heavy foot)
Gpcalero
SW Florida
I have a cammed and lifted Alpha T and still on the OEM transmission, not far from your miles. Like Amrg said, 126k miles is pretty good for the original trans, cammed or not. Some people have had them kick the bucket both long before and after 126k so I don't think the cam has much to do with it as much as the driving style did.
That being said, there are a few things you could do to replace it. Could go with a used, new or refurbished unit (cheaper option), OR you could have yours built. If you decide to built it, there are A LOT of different options available. Really depends on what your plans and budget are.
A low level rebuild with some upgrades may last you another 100k miles. Or if you plan on going big power like I am, you could always upgrade the input/output shaft with new 5/6 pinion planetaries and much more. Lots of options you can do to beef up the 4L60E, but again, it depends on you.
Ordieh
Georgetown texas
If you have a reputable shop available (I’m lucky.... have a tranny guru nearby ) , have them build your original to exceed 4L75 specs. with mostly GM parts (such as five pinion planetaries etc.) Go with Z PAC instead of GM clutch packs and be sure to use a metallic 1-2 accumulator. Don’t forget a Corvette servo. I currently have this set up in my CE after really good luck with the same build in a pretty radical LS powered ZR2. Good luck!
StandoutAlpha
Minnesota
Right now im on 275-65r20 thats a proximity 34in I'm planing to go with 35in soon
