WTS 2003 H2 For Sale - $13,500 18447 PA
5gn-h3t
Northeast Pennsyltucky
REDUCED - 2003 H2 For Sale - $13,000 18447 PA
UPDATE: I removed the BTR Stage II truck cam and installed a factory stock cam. Everyone that looked at it so far DID NOT like the aftermarket cam. It now runs and drives like normal.
I have too many projects, too many cars, and not enough time or money. So, the H2 is going up for sale. Price is firm. I bought it back in October from a local dealer.
I bought it with some "little things" wrong with it. Check engine light was on. Gas cap was broken, so I figured it was emissions related. I was wrong. It was a P0300 random misfire code. I replaced everything external to rule out any internal engine problems. Then found out the code was caused by a stuck lifter.
All parts have been replaced within the last 2,000 miles.
P0300 related new external engine parts:
Fuel Pump (OEM AC Delco)
Fuel pressure regulator
Fuel cap and plastic surround
Spark plugs and plug wires
2 New exhaust manifolds
New crankshaft position sensor
Internal engine parts:
New lifters
New trick flow pushrods
Replaced a few rocker arms
New oil pump
New timing set
Heads reconditioned and milled .030 to get LQ9-ish compression ratio
New LS2/LS3 Valve springs
New valve seals
All OEM GM bolts, gaskets, etc., etc.
Other items replaced:
Transfer case shift motor
New Rancho front shocks
Replaced passenger front lower ball joint
Gauge cluster has been rebuilt with all new stepper motors and bulbs
New smoked roof marker lights
Differential and transfer case fluids were changed when I bought it.
New idler arm, idler arm support, and pitman arm. (7/12/15)
It's my daily driver, so the mileage will go up a little each day. I enjoy it and it's fun to drive. If I don't get my asking price, I will just keep it.
Has a DVD player in the roof console. They are not in the pics, but I have 3 oem roof racks (with keys!). I also have a chrome brush guard that can go with it as well.
Has H2 Limited Edition chrome rims. Also not in the pics - I have the spare tire and cloth cover. I do not have the hardware to mount it.
Known problems:
No catalytic convertors. This may be a problem depending on where you live.
The mirrors are aftermarket and the driver's side power mirror doesn't work. You can move the glass by hand.
Paint and interior are extremely nice for an '03. Tires are good. No check engine light. Rear O2 sensors have been deleted in the PCM but they are present and unmolested.
5gn-h3t
Thanks. Now I'm thinking about keeping the H2 and selling my H3T. Not sure what direction I'm going in yet. I have 3 HUMMERs and don't have time for all of them. The H3T is by far the coolest but I enjoy driving the H2 more.
5gn-h3t
Last chance!!! $13,000. I got an offer from a dealer for $12,500. It's going one way or another in the next week.
Everyone that I had look at it DID NOT like the cam. It now has a factory stock cam in it and runs and drives normal.
