H3 2006 H3 Rancho Lift Shocks
jphh20
CT
Just bought a Rancho lift and looking to find a better alternative to the Rancho shocks. I am currently running Bilstein 5100's on my torsion bar crank and realize that with the Rancho I need to get the right shocks. I had been happy with the 5100's and I am having a hard time trying to get the right part numbers that will work with the Rancho lift. I tried doing a search and was not able to find what I was looking for. I plan to run the standard Rancho spring under axle for a while until I am ready to make the leap to the SOA mod.
Here is what I have been trying to search for (Lifted Chevy Truck 4")
Front shock p/n ?
Rear shock part # 24-186636 needs bar pin eliminator to work
Any suggestions to try and find the right part #'s? Sorry if these questions have been asked before.
Thanks
Joe
Search "Rancho redux" in the search bar. 06 H3 has a thread about the fronts. Or you can click on his profile and go to the "started threads" tab. There's a few pages to scroll through but you should be able to find it. I used those shocks with my Rancho lift and I'm really liking how they ride.
jphh20
CT
Thanks for all of your responses and looks like I've settled on these:
Bilstein 5100:
Front Part Number: BIL24-185950
Technical Details
5100 Series Shock Absorber
Collapsed Length (IN): 14.15
Extended Length (IN): 21.38
Travel Length (IN): 7.23
Lower Mount: Clevis
Upper Mount: Stem
Shaft Diameter: 14mm
Reservoir: No
Finish: Zinc plated
Body Design: 46mm ID smooth body (Non-coilover)
Internal Design: Mono tube
Boot Included: Yes
Rear Part Number: BIL24-186636
Technical Details
Bilstein 5100 Series Shock Absorber
Collapsed Length (IN): 18.17
Extended Length (IN): 29.92
Travel Length (IN): 11.75
Lower Mount: Eye 14.12mm
Upper Mount: Eye 14.12mm
Reservoir: No
Finish: Zinc plated
Boot Included: Yes
I was able o get all of tis information from this forum. Thanks to all the folks who posted all of your builds and suggestions. Does this look like good choice?
