GreatDaneHummer
- Chicago
Anyone know a way to fake out or block out the ABS / Traction control completely? I do not want to run it on my new SAS? Thanks!
Currently for testing I have the two front sensors removed and it does give me an ABS error etc also not allowing me to shift into 4 low. It hasn't gone into any low output mode or anything. I would like to use this unit bearing without having to modify an outside sensor ring. If none of this is possible then I will have to go old school way Dana 60 hub/spindles.
http://www.spidertrax.com/Ultimate-Unit-Bearing-8-on-6-1-2-x-RH_2
Yes transfer case shift functions work fine.
