Air filter box compatibility.
Thanks. Installing the snorkel soon, and they do not easily adapt to the first gen boxes and the OD air compressor mounting plate will not work with the first gen boxes. 2 reasons to change I guess.
GoBlueHummer
Michigan
The mounting holes are different on the later models. The holes don't like up so you will have to figure out how you want to fasten it down. I ended up using M8 50mm (i think) bolts with large fender washers and lock nuts. Like Speedy said , you do have to open the hole up a little more too.
