Background: Was wiring the OEM grill lights, disconnected the NEG battery terminal, lifted the fuse block out of the tray to install the connector and now my key is syuck in the ignition. I have disconnected the NEG cable and re connected, verified both terminals are tight. Battery is less than 90days old. I have taken apart the steer column plastic to push the little silver button behind the key cylinder (I think its the right one, its the only button I can find. Its on the black connector towards the firewall), made sure relay 88 was secure (tip from another post). The truck also wont start, no power or dash lights. Any help would awesome!
