GoBlueHummer
- Michigan
Did a search but didn't find anything. I need to replace my rear shocks and saw the Fox 2.0. How do they compare to the Bilsteins? The OEM's?
Thank
Thank
Biggest benifit of the Fox Shox would be the fact that its rebuildable and can be re-valved.
Never ran them personally but have heard alot of great things about them.
Is your rig lifted, leveled, 100% stock?
Bilstein 7100 series with reservoir are just as good as the foxes minus the price tag...they are rebuildable revalve for about $125
Torres
Torosion leveled.
Also, just to be clear, I'm looking at the Fox 2.0 without reservoir. I didn't know the Bilstein 7100's are rebuildable, that's tempting but still a bit more than the 2.0's at ~$120/per.
I had a 5100 blow prematurely on the front which is why im considering others for the rear. Still running 5100 on the front.
Where are you finding the 7100s for $125? Everywhere I looked it's close to 200
DW...these won't fit the Rancho due to the mounting. They are a universal eye-to-eye shock, 2.0" body with reservoir, 10-inch travel, custom-valved and charged with nitrogen by Downsouth Motorsports (San Diego). They were $1000 for all four. I'm sure you could get a standard pin type mounting (for the front) or a t-bar mounting (for the rear), if you wanted. DSM is a large-volume Fox dealer and they can get anything you need...reservoir or not. They do all the custom valving in house, and they will do free adjustments (you pay shipping), if required. IMO...Reservoir shocks are pointless on a stock IFS H3...there isn't enough travel to warrant the extra volume of a reservoir. A high-perf mono-tube is better choice (and half the price).
Just something else to think about, the fox shocks have very easily sourced parts. If you ever back into a rock, blow a seal, whatever... the fox shocks are easy to fix, and easy to work on. The bilstein's on the other hand were less available.
I just got a set of 2.0's I got for free with a bent shaft, I'm having my shock guy toss some TI shafts in them & bump compression on them a tad... and it's pretty simple to get done.
