FYI, just a way to think about clocking your existing torsion bars to return to stock settings with the new weight...
If you ride dirtbikes, sleds, mtn bikes... anything with an adjustable coil-over suspension:
Clocking up the existing bars is almost the exact same thing as moving the coil adjustment nut a few turns because you've got a heavier rider. The preload (suspension setting for different weight) will change because you're "compressing" the shock a bit (turning it into the load) and the spring rate will change for the same reason. By clocking the spring more, you'll have a stiffer rate at the beginning of the stroke, and at the end of the stroke... Now of course, some times adding preload still doesn't give us the characteristics we were looking for (too stiff a start with an overly linear stroke, minimal bottom out protection...) but in this particular instance, I bet it would be worth a try.
I've just found that because of the abnormal nature of a torsion spring, that many people don't think of them in the same way as a coil, so it's good to draw a few parallels so that they make a bit more sense.
I'd try that first before spending the $$ on new springs.
