Are there ''PLUG-IN' LED tail lights that work on the H3
deserth3
Conroe, TX
I no longer have my 3. But I tried a couple different kinds. Each time I ended up going back to OEM.
But if there are any around anymore you should be able to find them on Amazon and ebay.
I also believe the company I used stopped making then.
If you try just the bulbs make sure you use a resistor. Also if you put an Led for the reverse lights. Your rear view mirror will stop auto dimming. At least my 06 did.
Sent from my SM-G991U1 using Tapatalk
