Auxiliary reverse lights?
H3TDave
West Virginia
So I got into a situation the other day where I could have really used some extra light while backing up. I was wondering if anyone has any suggestions on mounting some extra lights. I was thinking of some flush mount lights in the rear bumper.
Sent from my SAMSUNG-SM-G891A using Tapatalk
I used flush mount light in my Thor parts bumper and have been happy with it so far, I would suggest doing it and having it set up to come on with the reverse lights by taping into the trailer harness (if you have one)
H3TDave
West Virginia
That's the way I'm leaning towards. I'm gonna have to get creative on fitting them on the rear bumper.
Traxx
PNW
I have a set of the other style of RC flush mounts, the 6" ones. They are just long and wide enough to replace the markers(with a little cutting) in the rear corners. On my list of projects to do.
Panzer07
Ontario, CA
I got some lights like the ones u got I haven't wired them yet since I was waiting on my waterproof relay, hopefully I get to it tomorrow. In taping into the oem back up lights.
Doing the same he did.
https://youtu.be/ZVG7X-ae298
H3TDave
West Virginia
So after some looking and measuring the license plate needed to shift to the left and I'll have to fabricate some spacers so the lights won't hit the tow hitch behind the bumper. With a lil bit of creativeness and patience I believe this project will go smoothly.
Panzer07
Ontario, CA
I really like your tire cover.
It is pretty functional...just more that it comes with a clear plastic originally but as any clear plastic that's expose to the elements and sun will go yellow...in this case work for the best since I just cut it so I could install my license plate and back up camera.
As well the window is for a 17" rim but the stock 16" works as good
Rampage Products 783535 X-Large Window Pane Tire Cover (Black Diamond with 17" Diameter Window) https://www.amazon.com/dp/B005BCT026/ref=cm_sw_r_cp_apa_knyxzbKSYW548
