StandoutAlpha
- Minnesota
B0790 & B2725 Codes Help [SOLVED]
[SOLVED] <-----------------------
**Had 2 wires mismatch and plug in wrong**
After removing my whole dash to replace the AC Evaporator Core and putting it back. SERVICE 4WD comes up on the cluster. Using my BlueDriver OBD scan tool/app.
Codes show up:
B0790
B2725
Already replaced the 4x4 selector switch to a NEW one but codes still remain even If I clear them it comes back.
Amber light on the 4x4 switch stays on 4HI LOCK and it blinks/flashes really fast and also cannot switch to other modes. *See picture circle in red*
Another thing is that the 4x4 switch doesn't lit up/illuminate the passenger seat belt or airbag on/off light *See picture circle in blue*
What is wrong here? Did I miss a ground wire somewhere or my Transfer Case Control Module needs a reprogram since I unplugged it when I removed the whole dash?
Codes show up:
B0790
B2725
