Beware body lift owners
gfbh3t
Lockport, NY
Anyone with a body lift should make sure that the part of the fan shroud that rotates is very secure! I was making a hard left turn and the shroud slid down into the fan blade and went through the radiator.
This happened with another member here, had the shroud rotated and bolted in place only to have the bolts come lose and the shroud rotated and wen't through the radiator. Sucked for him since we were 50 miles offroad and I ended up towing him back to the road!!! Towing over the sand dunes was challenging!
humvee
Doha, Qatar
Yes, same exact thing happened to me. Ended up cancelling the bottom part of the shroud completely. Monitored the temperature and found it had no effect. Also retained the radiator, cancelled the affected line.
cbetts
NERD!!!
Rancho Palos Verdes, CA
I ran self-tapping screw right down the top so I could keep an eye on it while performing regular maintenance, like oil changes.
Sent from my Pokemon Go appliance using Tapatalk
gfbh3t
Lockport, NY
Did have 3 self tapping screws in it. Didn't work out to well. Just picked up a cheap one from autozone. No longer running other half of shroud
atvspeed4
massachusetts
Same thing happened to us last month...took lower shroud off and haven't looked back. We figured out that our engine mounts were worn and rotated the engine over and caught the shroud spinning the lower shroud around and into fan.
Vdawg1115
Oakland, CA
I am assuming this only effects 5cyls with the two piece shroud......I think the Alphas had a one piece shroud, cause I remember changing my radiator and the instructions didn't line up at all cause they were for a 5 cyl
Lchase
Georgia
I had the same thing happen last year after going thru a deep mud hole, it let go on the way home when excellerating up a hill, i also came to find out my motor mounts were shot which also helped it make contact. The painful part was the radiator was only a month old.
cbetts
NERD!!!
What brand of body lift was used and how much of a lift was it? Thinking about installing a body lift.
I believe DayStar is the only company offering an official H3 body lift kit. It is 1". I would not try to go more since it pretty much pushes the limits of connecting components like steering.
humvee
Doha, Qatar
Important thing is that its been tested, lower shroud removal doesn't affect i5 running temperature.
And can confirm that the V8 shroud has no such issues.
