Body bushings replace on my H3..
lsv_palana
Kamchatka, Russia
Hello dear friends ! I think time come to replace body bushings.. i search all around internet on not found any polyurethane bushings. so i must use original.. but they are cost a ton of money... maybe we can use something else ? or i can repair my old ones ?
I've not dealt with them, but couldn't they be rebuilt if you could find a local shop that can buy some polyurethane stock and mill it to fit?
SGT-Wright
Washougal WA
I have seen some generic red bushings on Summitracing. I need to replace body mount bushings too and am having problems finding anything but the OEM. Are the Colorado/Canyon mounts the same size? I am sure someone here on the Hummer forum has replaced body mounts and can guide us to where to get something better than the OEM unless the OEM are the only ones worth using. I have already inserted some extra rubber washers into the most warn bushings to get them to tighten up and remove the gap, but now I want to put all fresh ones. I am at 136000 miles and things are getting loose and noisy!
