BPM an BTM the same?
deserth3
Conroe, TX
Yes, same procedure.
Hate to disagree with you. But the H3 is different. On the H3 you hold the RPM at a steady rate and traction control will sense the the wheels slipping and start pulsing the brakes. Can't remember the RPM off hand. Someone help here?
LagunaH1
Idaho
Same procedure... This topic is also a HUGE can of worms... there are LOTS of opinions as to if / how BTM / BPM works on an H3
lol yep...a big can of worms.
I never heard of BPM though, I may call it that just to argue that its not BTMing like an H1 its BPMing!
Desert, I think we're talking about pressing the brake and the accelerator at the same time, thus manually applying the brakes to limit wheelspin. And by applying the brakes, you automatically override the traction control. So, if the OP is talking something else then I could be way off base.
Note to everyone: notice I didn't touch the topics of effectiveness, or how the technology gets applied, or any of that stuff. I just said "Yeah, brake and gas at the same time". :)
deserth3
Conroe, TX
Yes, I knew exactly what your talking about. And yes you can BTM a H3. I was trying to point out you don't need to. The H3 will see the slip and start applying the brakes automaticaly. All you have to do is hold the RPM steady. IMO it works better if you let the truck do it and puts less strain on the drive train.
Cool, we're on the same page then . . . except, I tried using TC on Hell's Gate and I immediately slid off the wall as any wheelspin before the TC kicked in led to disaster. Using BTM helped me better control the wheelspin and climb right up.
That said, I still use TC often in other situations.
jakesz28
Cabool MO
Alrock, I agree. I have only wheeled in Moab and hard rock once. But there are times the traction control is priceless. But other times it did not work so well and I had to hold the brake pedal. Different situations call for different measures. I have videos were the traction control in mud on tree roots was the way to go. But I prefer being able to lock the axles I want to pull thru the situation on demand.
Highatop
Florissant, Co.
Ok, I tryed closin the box or can. Now, My next question is...The clickin I hear when, mostly climbin. Is the TC workin and not a bad thin. I do try and stop that when I hear it but only after the fact and do not let my wheels spin to much. That was w/ 285s A/Ts. Now have 315s Duratracs and have not really used them wheelin yet, Snow yes w/ the tires and happy so far.
I'm not tryin to start trouble. But...
If you're looking at slow, steady throttle then yes, that's likely the TC working. It uses the ABS to minimize or stop wheelspin.
LagunaH1
Idaho
X 2 on what alnico said. TC working sounds a lot like AB'S working.
Sent from my SAMSUNG-SM-N900A using Tapatalk
