Dinglezz
- Ontario, Canada
Ok , my first post so try to be gentle. 2006 Hummer H3, 3.5L 5cyl. 200km
Recent work completed, new trans cooler, new rotors and pads, new left wheel bearing, fixed fuel pump and ran new lines.
Brake light recently came on (like the park brake light) and I've checked the following. The park brake fuse, the brake level, the brake lines, all the pads and rotors. Not down any fluid and no leaks. Also have the ABS traction control light on, but have been emptying 1/4 can of electrical connector cleaner to the plug under the transfer case as per the direction here.
Braking in the hummer is unchanged. No difference in pedal feedback, and hummer stops normally. I did notice that when I have to slam on the brakes for random idiots around me, the hummer does seem to dive hard front and pull slightly front right??
I thought initially I had a seized caliper but checked all them and they still work all though could all stand to be replaced. Someone mentioned air in the brake line??
Any advice greatly appreciated.
Thanks in advance
Thanks in advance
