Bruces
- Portland, TN
C0388 issue / fix
I have been getting an error code pointing at the rear locker. It has been intermittent and went away after cleaning the connection at the rear differential. Then last week it came back and would not go away. Crawled under today to check the connection again and found harness had worn completely through at where it is tied down to top lip of fuel tank. Resoldered everything and working fine. If you get this same intermittent issue you may want to check harness where it comes over fuel tank.
