CAMPERS for H3T
TravisUsmc
Houston
OK so I am looking into the best camper for the Buck. The ARB is around $3,500 and is pretty good looking. The only downside is that you can't see out of the back.
Is there any soft tops or other campers out there that anyone else likes more? Please suggest some to me.
Travis K
Sent from my DROID RAZR HD using Tapatalk
TravisUsmc
Houston
Not really like that. Haha. Gunner I did see the one you sent and that one looks really cool. Pop it up when you need it..
I do not see much for the H3Ts
What amenities do you need? FSC? just a spot to crash that doesn't require completely removing your gear?
I had a Chevy Blazer - 78 - that someone had put a camper on, I thought it'd be the cat's pajamas - but it didn't work for me... it was heavy, it made the rig even more top heavy, and it wasn't that comfortable because it just didn't have the space inside to comfortably stay out of the elements.
(Looked similar to this)
I actually have two camping set ups.... a tent (even multiples here because I have a solo and a group set up), and a slide-in for my 3/4 ton truck.
TravisUsmc
Houston
I'm looking laying everything on the table to see what all company's make a top for the back. I have a fold over on mine already. It works well but I want something larger for travel and off road adventures.
You could go with with a snug top slant back. I think you can see out the back, not sure tho
You cannot see out the back at all.. You have to learn to trust the backup cam big time!
I use a CVT roof top tent on my T and I think it's perfect!
Find level ground pull the cover off and then pull the ladder out and down and you 99% down you set up
