Can it be done?
rsc
Tulsa
I was wondering if replacing a transmission is something that could be done in the driveway without special tools or if it needs to go to the pro's with a lift and a shop? I see lots of rebuilt or low mileage 4L60E's around here for 1/3-1/4 the price a shop would charge.
whylee
Reno NV
It does not take any special tools, just a good assortment of sockets, extensions, and wrench's. A good tranny jack would really help and a friend or 2 makes things much easier. With that said, I have done it alone before. If you have not done a tranny/transfer case before, it would be smart to have someone who has help out.
Pappibri
Cohoctah, MI
If you have decent mechanical skills its no biggie... Just give yourself plenty of time and make sure you have all the tools you need before you start..
New Jersey
I've never rebuilt one before, but what is it you actually do? Replace what you see damaged as you pull it apart? Or gut it out, and replace all the inside parts to new parts and seals?
High Five H2
West Texas
there's a company that makes manuals for the transmission and it will tell you how to rebuild it. I think you can get a rebuild kit, too.
Be aware the H3 version of the 460 has some special parts that others don't....stuff like the pan and valve body have been altered at the factory to allow for front driveshaft clearance. There may be some other internal items that have been shifted around, making the H3 version rather special. For this reason, you might want to make sure you get a rebuild kit specifically for the H3 (and not just a generic one). I don't know the extent of the differences but, the H3 automatic is unique to that chassis and swapping a 460 from another vehicle turns into quite a job. CaseyS seems to be the H3 AT guy (whether intentional or not). He has pulled his numerous times, and can probably shed some light on this.
I've pulled many an AT on other vehicles, and it truly ranks as one of the most awful jobs there is. Once the AT is out of the vehicle...I take em to a pro. There are very few components on a vehicle that intimidate me but, the AT is one I stay away from. Its too big of a job to re-do if I get something wrong. To my eyes...the internals are nothing more than a mesmerizing tangle of cogs, gears, bearings, springs, check-balls, and shiny metal parts!
"A man's got to know his limitations" - Clint Eastwood
rsc
Tulsa
I was expecting to have to switch the tailstock out from 2wd to 4x4 and replace the torque converter but have no plans to open one up myself, even with a book guiding me. I had forgotten about the pan differences, but that is easy to swap over. Same for the valve body, but those are the things to know before pulling it and dropping the core off. I don't have a jack for the tranny, but know the transfer case can come out without help. I'm not really wanting to do this in my drive as it has a little slope to it. :/
CaseyS
Louisiana
Short answer, yes you can.
Long answer, depends what you are trying to do.
To get the transmission out is not extremely hard. You will want a transmission jack to support it. I got mine at Harbor Freight. Transfer case comes off first. Support the transmission with the jack, remove the cross member and let the tail end sag down. Remove the shift linkage and wiring. You will have to rotate the engine to get to the flexplate to torque converter bolts. You will need an offset wrench to get these bolts out. Standard wrench won't work and not enough room for a ratchet and shallow socket. Once it has sagged down, you should be able to see all the bellhousing bolts. I recommend about 24" of ratchet extensions to get to the bolts on the top of the bellhousing from the rear. The cooler lines are last. They have a quick connect that has a retaining clip that is almost impossible to get out. I just unscrew the quick connect fitting from the housing. At this point you should be able to slide it rearward. Vent lines slide off last. NOTE. Once the trans is on the trans jack there is not enough clearance to slide it out from under the truck. You will need to jack a corner to be able to roll it out from under the frame rail.
Now on to the next question. If you are looking to just replace the transmission, not any 4L60e will do. See my rant in my build thread. Forget about buying a 2wd trans. The output shaft is the very first part that goes into the case. In order to swap it out to a 4wd output shaft, all the trans internals need to come out. The second thing to look for is the input shaft and bellhousing. The I5 bellhousing is specific to the atlas engines, it's not standard chevy pattern. All the later 4L60 have removable bellhousings. You can swap that rather easily. This requires a special torx bit to remove the bolts that is a special order. You can't find it at Lowes or Home Depot or even Sears. You also need to make sure the input shaft is the type that supports the 245mm converter. If you have the wrong input shaft, the trans has to come partially apart to change it out, plus sourcing the parts, etc. If all this is correct, the pan, valve body, 1-2 accumulator and spacer plate all need to get swapped from your original trans to be able to clear the front driveshaft. If you pull the valve body, its crazy not to spend the few bucks on the paper gaskets that go with it.
I rebuilt mine, mostly because once I got into it, I wasn't sure what combo of parts I was going to need to make things work. With my swap, I needed the front end to look like something off of an LT based v8, the bottom end to have the H3 compatible parts. You can order generic rebuild kits for under $400 that include all the seals, soft parts, clutches and steels. If you go that far, another $100 will get you a few nice upgrades for longevity. The rebuild takes a few specialized tools for compressing some springs, but I MacGuyvered some of it and made it work without buying anything. The torque converter should be changed and should be a shelf item.
Here are my recommendations in order knowing what I know now.
1. Purchase used/rebuilt H3 trans and NEW torque converter. Will be a long one day project start to finish to pull old trans and install new one. Will need to invest in a tranny jack and maybe some hand tools (offset wrenches and ratchet extensions)
2. Same as #1 but carry it to a shop and spend $300 labor and let them mess with it and drive away clean and happy. Take the time you save and have a beer and watch some football.
3.Pull your transmission and carry it down to a rebuild shop and have it rebuilt. I would say $700-1100 range depending on shop. You will save the labor of pulling it and reinstalling it. For the money you save doing this, you may not get a warranty with the trans.
4. Bite the bullet and have a shop do a full rebuild on your transmission. Cost $1400-$2000 depending on shop. Shop around for reputation and best warranty
5. Find a good used/rebuilt 4WD with the correct input shaft configuration. You will need to swap valve body, pan and a few lower parts. This is likely the lowest out of pocket $$ option, but you could encounter a pitfall or two so be prepared.
6.Rebuild your own trans. Should be able to do it for under $600 with new torque converter. What is your time worth? Make sure to do plenty of research.
The big thing with any rebuild or cracking one open is the penalty for not having it right the first time. If something doesn't work, you are looking at another day of labor just to get it down to find the problem and reinstall the whole mess. Don't forget this includes pulling driveshafts and transfer case each time. I spent about $800 on my initial build including a $100 core donor for the right case, input shaft and bellhousing that I needed for my conversion. Once I had the right fluid fill, I think everything was right in the build. 2 weeks later, problems arose that I think ultimately was valve body bolts vibrating out. But I ended up pulling the whole thing down and rebuilding the pump again not really knowing at the time. A second failure happened when the torque converter solenoid also vibrated out, which burnt the torque converter clutch. I pulled it again and changed the torque converter during the summer. This partially fixed the problem and I eventually burnt it up wheeling from a combination of low fluid fill and high trans temps (my own fault). When I ultimately broke down on the interstate in TX, I was forced to have it rebuilt. The shop charged me a more than fair price of $1400. Picked it up 2 days later and haven't thought much about it since.
In the end, its all up to you what your time is worth vs the potential cash savings.
rsc
Tulsa
Well crap. Thats not what I wanted to hear. But, its what I needed to know. A transmission guy I know told me a while back that pulling the transmission was fairly straightforward, apparently I need to have MY transmission tore down and not try to order a generic replacement. Even having them do it, I think I had better print some of this out for them just to be safe while they learn H3's on MY truck. Thanks for all the input guys!
High Five H2
West Texas
i switched out the solenoids on a 4L60E from a camaro once. But all you have to do for that was take off the pan and there it is. auto trannies are kind of like women in that no one really knows what's going on in there.
Still, that $50 fix and diagnosis was a big victory for me because a shop told me it would need to be rebuilt.
rsc
Tulsa
I work with hydraulic stuff in aviation and at a manufacturing plant so I am familiar with hydraulic and p eudraulic stuff but an AT is a whole other ball of wax. Like Casey was saying, you don't want to be learning on a one-shot-to-get-right nightmare.
you won't do this
the 4x4 transmission has a different output shaft than the 2wd...
with that said, swapping a transmission it's not that terribly hard of a job to do, and that the rig is a 4x4 actually makes it easier. pull the transfer case first, then the transmission... trust me on this. You will wear ATF, makes a good hair softener.... the trick is to drain as much as you can first, drop the cooling lines, use a flush kit on those lines, then get on with draining the transfer case and the pan. You can drain the torque converter, but it's kind of a pita with the full bellhousing...
I'm a fan of putting in a drain plug (if it doesn't already have one) - if you do decide that route, get a metal roofing self tapping screw, drive it into the pan, back it out and let the fluid drain. once it's mostly drained, screw the screw back in - you won't get all the fluid out, so plugging the pan is a good idea
If you can get help, get help from someone who's done it before... if if they kick back and watch you get gooey.... having someone who knows how to pull the flywheel bolts and how to get to the top bolts can save you a lot of time and grief your first time.
with that said, there's plenty of guys on YouTube who posted up videos... watch them, they're very useful.
