Cat Converter
H3nightrod
Illinois
I am getting code Po420 Bank 1 in my 2008 H3 Alpha
I took it to local shop and looks like I need the left top Cat Converter. Shop says they are on back order and might take 30 day. So I looked in GMPARTSOMHOUSE.COM for part and looks like $481.95
Can anyone please confirm a part number?
Reloader
Montana a free state
All my cats got replaced under the 8yr/80K emission warranty by GM. The left side started popping the P0420 every 3K miles or so so that side got replaced first .
Then 5-6K miles later the other side went bad. Only front cats are monitored but both on each side get replaced as an assembly. I've since had the rear cats cut off and pipes installed.
Makes a difference in noise. Sounds better with the new Flowmaster and dual 3 inch pipes out the back.
The dealer told me this is not uncommon with the 5.3 V8 in all GM applications. Do you have over 80K on your 3? If not get it to a GM dealer. Even if your are over some they may take care of you. Good luck.
Reloader
The front cats are mounted pretty close to the exhaust manifolds and its a tight fit there to be welding in new ones without removing the pipe assembly. Plus finding a cat that will fit and the engine management will tolerate might be an issue. Aftermarket cats can be a big pain in the a$$ on a lot of newer vehicles. I've had lots of experience in this. If you go with an aftermarket cat assembly be sure the installer will stand behind it if the problem returns. We would usually credit them if they agreed to upgrade to OE cats and pay the difference on the parts and pay to install again. We also made this clear before even doing the job the first time. We would send the aftermarket cat back as a defect for credit as it wouldnt work properly.
Another thing that can work is to install a thing called a spark plug anti fouler. Its a small fitting that moves a spark plug out of the combustion chamber a small amount to prevent oil fouling on a cylinder that is using oil. Its an old school device that can be used to move the post cat O2 sensor out of the exhaust stream to stabilize the voltage signal it sends to the ECM. NAPA sells them and you need an 18mm one for the larger spark plugs. You have to drill it out a bit so the sensor bulb will fit. You might even find one online thats made specifically for this.
When a cat starts to fail the post cat O2 sensor starts to mimic the precat sensor and that triggers the sucks to be me lite. If you scope the sensors on a healthy cat the precat voltage will be crossing over the .5 volt mark .1 to 1.0 volts regularly and the post cat will stabilize around the half volt mark and stay there. Readings on a bad cat will be almost the same.
Unless the vehicle is a Toyota, then the precat air/fuel sensor will fluctuate between .1 and 4.95 volts and the post cat sensor (still called an O2 sensor) will still read about .5 volt on a healthy cat.
Could also have a tuner turn off post cat monitoring if thats possible.
Sorry so long.
