I have found a lot of threads on this issue since I purchased my h3. The day I drove it home, the gauge made me a little nervous being near the 3/4 mark. (I think we are programmed as humans to want it to be in the middle, all other gauges are). After replacing cracked radiator, and of course hoses belt and thermostat, the gauge still rode there. Found a good use for the lemur obd2 Bluetooth, the highest it would read was 210, jumping to around 215 when I cut it off and let it sit, crank back up, it quickly falls. Changed radiator cap today, just cause I was in the parts store and it was all I had not replaced. All day long, steady 207...92 degrees here in sc with a "real feel" of 105! Traffic, stop lights, high speed and low. Gauge now sits steady and slightly above 1/2, and with no movement up and down. Just food for thought here, 12 bucks has made me a happy man today. I melted a z3 motor in a matter of seconds due to a poorly designed Oem gauge that jumped from middle to pegged like you had thumped the needle
oh well , live and learn.....
