- WI
I supposed this has been discussed ad-nauseam in the past.
1) What I noticed on my failed upper ball joints is the 'root cause' of b/j failure seems to be the grease dried up (first), then wore out the plastic bushing. What have you guys noticed?
2) I drilled out my old one. The steel cap is about 1/8" thick. Has anyone tried to drill a small hole slightly off-center (not directly on top the main ball pressure zone) to grease with a needle grease tip? For those who've cut one apart, where would be the 'best' location to drill a tiny 1/16" hole? (not one large enough for a zerk)
3) Given that these upper control arms are pretty easy to change anyway, maybe it's not even worth trying to grease up ....and better to replace after 75k or whatever life ya get?
4) I bought GM control arms, but I'm wondering what the value is buying the more expensive GM control arms compared to the cheaper imports that are about 1/2 price? What have you noticed? The b/j is basically a nylon cup and hardened stud pressed in, then capped. Doesn't seem to be the level of craftsmanship or metalurgy as old-style ball joints. The b/j will likely wear out faster than the bushings ever will. What have you guys found, do the less expensive aftermarket control arms ball joints seem to last about the same as the GM/AC Delco's? Anyone make an improved upper control arm/bj?
Like to hear your ideas..
Cheers!
Cheers!
