I saw your comment and it disappeared.. Not sure what happened either. I left the old rubber in because I tried to drop the crossmember but the sun was going down and said screw it. Added a washer on top of the rubber, in between the crossmember and axle, as well as metal rings at the head of the bolt. The metal sleeve from the bushing is still in there. I found that in park I couldn't tighten it down all the way and when in drive it would shift downwards, so I put the truck in drive (brother on the brakes) and cranked it down. Worked much better this way.
Same here. I posted twice on Monday and they're gone.
