DIC info?
So I'm not sure what messages I'm supposed to be seeing in the DIC on the dash... I get the "srvc tpm" message cause I don't have sensors in my rims. But what else does this thing display. I haven't run it dry so I haven't seen low fuel. Is there a way to access info in there? I push the stick and just get the trip meter. I've heard it monitors oil life but haven't seen any of that.....
Steve #1
TEXAS
You can't access any of the info in it. It only tells you when something is up. "change oil soon" "Low tire" "Stability Sys" "Reduced power" I think is what it says when it goes in to limp mode. "Service 4 wheel Drive"
A while back I compared some schematics and I think a module from a trailblazer could be connected to get more information.
3rdH3
Blacksburg, VA
All of this is in your Owners Manual. If you don't have one you can go to hummer.com and under Owners then Owner Resources you can download a manual for your specific model. There are a number if things that are displayed on the DIC. Good Luck
ive got one and read through it all last night. does the vehicle need to be off and the key in the acc position? I tried it with the vehicle running and all I got was the trip meter.
