Driver side headlight out
poweraidon
georgia
I recently just changed my battery terminals and 2 days later my driver side headlight won't turn on. Everything else works just fine. But when I turn on my high beams it will turn on. What could be wrong? Could it just be the low beam burned out or maybe I knocked loose some wires?
Probably just coincidence... Swap bulbs from side to side if you wanna double check. The bulbs are dual filaments so chances are, your low beam is just out on that side.
If it were wiring, the high beams wouldn't work. Probably just a bulb. Time for another upgrade.
poweraidon
georgia
Yeah I've been thinking about upgrading, and now it's the perfect time [emoji16]. But it's such a coincidence as soon as I change my terminals my headlight won't turn on.
poweraidon
georgia
I was yanking on the neg wire kinda hard because it was short... Maybe I made something loose or blown out the fuse? But I'm hoping it's the the bulb
