Eaton e locker Make offer
I have a non working 30 spline eaton e locker for sale. It worked great for years on 35s then after the SAS when I went to 37s started running the hammer trails and the pins sheared off and worked about 40% of the time. Then I rebuilt it and it worked great for the rubicon, gold mtn, gorman 2 times, local wheeling and after about 4-5 trips the pins sheered again. It seems 37s and the big rocks kill these pins and side gears. I dont know what to ask so make an offer. My suggestion is this is suitable for 35s and smaller and moderate/difficult trails. Once you start running taking harder lines on the rubicon and playing on hammer trails with tires bigger then 35s I wouldnt recommend it.
For what its worth. I bought my rebuild kit from Toms differentials in Idaho for $198 IIRC and rebuilt it myself, it was easy. These lockers on ebay going for new range from $700-850. I am posting it so someone can get their rig to a new level for a cheaper price then buying a new locker if they are willing to do a little bit of work.
Feel free to ask questions.
Cowboy
Alameda
Well I'm interested. I have an H3T with 35's and stock R&P.
I have never rebuilt an e locker, but it doesn't sound to difficult.
My concern is if anything else is bent or out of alignment now that it's been repaired a few times. What do you think?
How does $150 plus shipping to Bay Area.?
Mitch
Can't make it through the day? Back up, and get a run at it!
The carrier shouldnt be out of alignment or bent if it was it would have caused weird wear on the R&P which my R&P seemed fine when pulled. As for everything else such as side gears spider gears pins etc all get replaced. If you want I can send it to you you can rebuild it or have a rear end shop inspect it you install it then when it's all done and working you can send the money
Panzer07
Ontario, CA
If he don't take it, I'd be interested, if you won't mind assisting me with the install-rebuilt...although the after the tranny rebuilt and assuring you with the install of my front locker and your OC I believe I have a chance of accomplishing it myself.
Again if he doesn't take it. Saw this a little late.
Torres
Rear locker.
Cowboy then panzer then napalm.
Also on the topic of carriers the carrier has a center pin. If the carrier was that trashed the center pin wouldn't go in an out with ease. On a microscopic level you can have the carrier tested for excessive run out where you measure the carrier as it spins to see if it's out of round but as a R&P wears you can see the pattern on the teeth and mine were all fine with no teeth or anything chipped. I would say I'm positive it's fine but testing it to be sure can always be done.
Any other questions feel free to ask
napalmsticks
NM
Ahhh, ok. I thought you were talking about a front locker for some reason. Count me out.
Rear locker.
Cowboy
Alameda
I will take it. I have sent PM
Thanks
Cowboy
Alameda
Rear locker.
I think we are missing each other on the PM's. (510)867-7954
Mitch
