DO NOT INSTALL THE PCM Efan!!!!!!!!!!!!!!!!
The fact they still sell that thing is a mystery to me! I installed one 6 months after getting my H3 Alpha. I took a road trip to San Antonio, TX (about 4.5-5.0hr trip from my house) shortly after installing it (all other driving was just short trips into town). Well once out on I-10 the temp started to climb (I use a Scangauge II to monitor stuff). Just before I got to Houston, TX the temp went out of it's normal range and continued to climb slowly. My wife wanted to make a stop, so I pulled over and while she was inside the store I popped the hood and crawled under my H3 Alpha to investigate. Nothing at all was wrong, but it was running hot. My wife came back to find me laying under the H3 so my gig was up as far as acting like everything was ok.. I removed my lower skid plate to help get some of the heat out, and I left the hood open to let it cool back down. After that I got back out on the road and now both of us had our eyes glued to the Scangauge. It went 210, 213, 216, 218, 220, 224, 226, 228, 230, 235, and the highest I saw was 237F.....
I'm 100% sure if by a miracle it hadn't started to rain on us (it was during a massive drought in TX) that my lovely 5.3L V8 would have died a horrific death due to that POS Efan! We got to our destination, I monitored the temps as we cruised around San Antonio, and on our return trip I left after the sun had gone down. We made it, and I immediately removed that Efan, and installed all the OEM stuff back (thank goodness I saved it!!!). My temps went right back to normal and I had no more issues after that.
I emailed PCM of NC ASAP, and they honestly didn't seem to care, and said well we tested it here in NC without any issues. I can tell you right now NC and TX temps are nothing alike and that setup is NOT up to the task. I told them how it almost caused a perfect V8 to almost blow up, and that I'd like my $$$ back. That was like pulling teeth, and after going back n forth with them I gave up....
Issues with the PCM Efan:
1. Fan does not sit centered and I believe it makes hot spots (they redesigned the shroud shortly after with louvers on the offset part, but I was never emailed back with an offer to send me a free replacement for my terrible experience...)
2. The Efan itself DOES NOT pull enough air thru at cruising speeds to keep up with the heat being generated. (at idle it could keep up well)
3. Sounded like a 747, but it certainly wasn't pulling as much air.
4. PCM of NC lost my PCM that I sent in to have the Efan option enabled (took em two weeks to finally locate it and send it back) I couldn't drive my H3 in the meantime...
The only good thing about the Efan setup was the wiring harness and relay. It was very well made and wrapped. It's the only thing I kept of the entire kit (I later wired in an aux efan of my own along with the OEM fan clutch setup, and I am using a 96-98 Ford Explorer 5.0L V8 Metal Fan Blade vs the GM Plastic Fan Blade).
IMHO avoid that kit like the plague, and find something else or do like I did and leave the OEM setup, get a new fan clutch, and wire in an aux pusher fan to help.
