Engine Codes on H3 Hummer
Schwarttzy
Rockford IL
Interested if any of you had these problems and what did you do to fix them. So far I thinking a new Mass Air Flow Sensor and Vapor Canister Vent Solenoid should take care of the problems. I seriously doubt it would be the gas cap for the P0455.
Fault log report generated by Torque for Android
Vehicle VIN: 5GTDN136X68227871
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 12606370 12601134 1260
Current Fault Log
P0106: Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0122: Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0222: Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223: Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0455: Evaporative Emission Control System Leak Detected (gross leak, check fuel cap, piping etc)
P0442: Evaporative Emission Control System Leak Detected (small leak)
P0068: Unknown code - More information may be available on the web Pending
Fault Log
ECU reports no pending faults Historic
Fault Log
ECU reports no historic faults
Other discovered fault codes (possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged End of report
