- WI
I'm wondering what gives? Like to hear what you guys think:
There is excessive up/down play at the inner half-shaft on the driver's side of my H3. This 'excessive play' assessment is based on the amt of movement of the opposite axle where it leaves the diff ....and relatively little movement I've noticed on other H3's I've looked at, and just general cars I've worked on over the years.
So I removed the outer axle housing expecting to see chewed up or rusted bearings, but they look good. No pitting, spalling or anything. The axle looks good too where it rides on the bearing, and mic's out parallel (not tapered). The inner coupler seems tight. I'm wondering where the excessive play comes from? My experience has been if the bearings look good they're probably not worn. 160k miles on rig. Regardless, I ordered new ones and a new seal, so we'll see how it goes.
What have you guys noticed?
