So, truck was making some very loud sounds last time offroading. Loud grinding and popping when I was locked or when on the street while turning.
I drained all the front fluid... not a single metal shaving, fluid is super clean. I have not removed the front cover but do not see a reason to.
Inspected the half shafts, if I twist them, they may rotate about 1mm before making contact. I think they have always done this, normal??
Tie rods are all solid, no movement.
Front diff crossmember..... Ive already broke one of these, and it didnt sound like this. However, James did break one wheeling, and now that I think about it, my truck was making the same noises. While, the nut has not dropped from the bottom like last time mine failed, there is about a 2-3mm gab between the bushing and washer (located between the diff and crossmember). Some one tell me if this is normal!!! I took a 3/8" ratchet, and was able to turn the bolt very easily and tighten up the bolt and eliminate the gap. Still have not test drove it (all the ucp is hanging loose). But thinking about it more, if my diff cross member bushing was loose, and it was moving, it was also transmitting the sounds thru the UCP, making me think I had a huge fail of sort.
Input..... anyone. Somebody take a look at there front diff bushing and tell me it they have a gap please. I really want to go wheeling this weekend.
