- Meridian, ID
I'm having similar "popping and binding" issues...and I have none of the IFS stuff.
I thought I would mention that t-case issues can also cause noises like this. Mine has become so bad I'm going to pull it out for a rebuild. If I keep driving around with the t-case like this, it will damage the diffs for sure. Several times I have read threads about t-case and diff failures at the same time (trailbreaker)...and I always thought it was strange that a dealer would replace both at the same time. Now that I'm experiencing the t-case problems, I can totally see how it would destroy anything downstream of it. My popping sounds awful, and its not something minor. I'm not saying that's your problem, just saying that noise from the front axle....isn't necessarily the front axle.
Jeez these things (H3's) are a pita to troubleshoot.
We need a thread for this, I am curious what the issue is with the H3 t case. I know you said your fluid was nasty after 40k miles. Would that affect it? So how tough is it for you to put a VSS sensor in an manual shifting gear driven t case? I know its gotta be in the back of your mind. lol
