Front end rattle
Enter Hummer
Southwest
I would at minimum remove the front drive shaft and run it 2wd so you don't destroy your T case.
I can remove it but can you explain why it would destroy the T case? I was under the assumption that the only thing that could happen would be the teeth breaking inside the diff, but I’m probably wrong.
