Front up travel limit?
Who knows what the limiting factor is with front up travel? I have the Rancho and I am thinking of shortening the extended brackets for the bumps stops. The lower A arm is about .5" off of the stop, If the shock and bump stop are removed what would be the limit? Tire rub, suspension binding, CV? Looking to max out the travel.
I would assume tire rub. The front end bottoms out without a steep up angle on the CV but it's been a while since I've looked closely
