Chop the frame.
Cut the cab in half.
Remove the rear doors.
Shorten & re-weld the cab to make a "bobbed" short-wheel base 2-door truck.
Part out the front IFS, 3.7L, AT, and AP t-case and sell em off.
Install a clutch/brake pedal set from a Colorado/Canyon.
Install a Cummins 4BT, NV-4500 5-speed, and NP-205 t-case with drivers-side drop.
Install a Ford drivers-drop Dana 44 front SAS.
Do a SOA on the stock rear.
Gear both to 3.73s.
Install 35"s on it.
Put a custom body-wrap on it.
THORparts front & rear bumpers of course.
Wheel the piss out of it and go places a Samurai won't fit!
I could only pay $8K for this bent T. I might re-coupe $3K from the low-mileage drivetrain. That would put me at $5K for the roller and fall within my $18K total budget for a diesel-powered, 2-door T, with a stick-shift. All labor would be done by myself. There would be no "adapting" the electronics. I would most likely strip the entire wiring off it...re-wire the rig with a generic "street-rod" wiring harness from Painless. No On-star. No TCS. No Stabilitrak. No ABS. No AC. No puters of any kind. Push-button start. Hit the window motors with a circuit. Wire-up the wipers, heater fan, and interior lights to switches. Install aftermarket tach, speedo, and gauges. Strip the carpet & headliner...weld-up the sunroof hole...tune it mild to get 24mpg...drive it forever.
As you can see...the thought never crossed my mind.
