Do you happen to remember the wire order that you switched them to?
I rearranged mine as well, but I had weird stuff happen, got low beams to work, then turn off the truck turned it back on an now high beams were on, but I hadn't touched any switches inside...
I got the lows to come on as they should. However i had to use a separate switch for the high beams. Luckily i already had a toggle switch already installed.
