H3 1" DayStar body lift install with a L5 engine
58Bisc
Warminster, PA
Before and after pictures:
ry%3D400
ry%3D400
Here is what comes with the kit. I found no use for the shorter bolts, the bed blocks or the V8 radiator hose clamp on the H3 with I5 engine:
ry%3D400
I found the DayStar instructions to be wrong for the H3 with an I5 engine for everything except the lift it's self. I've attempted to point out those differences to help others better prepare before starting this upgrade.
Be sure to have a good floor jack (the higher the lift the better) and a hunk of 3x3 wood roughly one foot long. I used an impact gun to remove the bolts. You will need a ½ drive 18mm and 22mm sockets, long and short extensions, two zip ties, a pair of cutters, a sheet of paper, a pencil and a tape measure.
Open the hood and look at the fan shroud. In my case it is a one piece unit, not a two piece like the instructions for the H3T show.
The lower part of the shroud (slip ring) sticks out towards the engine a couple of inches. When the body is lifted, it will come into contact with the fan.
View from below, looking up with the front skid plate removed:
ry%3D400
Look down the passengers side of the shroud and you will see a release clip.
View from the passengers side:
ry%3D400
Lift up on the post as you depress the release. The post should slide up towards you. Continue to rotate the post until you can't go any further.
This will put the lower shroud (slip ring) at the top and allow the body to be raised without hitting the fan.
ry%3D400
Since there is now no way to lock the shroud (slip ring) in this position, you will need to drill at least one hole (I drilled two) to place a zip tie through.
View from the front:
ry%3D400
This will stop the inner shroud (slip ring) from spinning back down to the bottom.
View from the top:
ry%3D400
There is no need to touch or trim the rear bumper caps on the H3.
The body lift itself, as you would expect is very basic. Measure and record the distance at each body mount of the body to frame.
I printed the frame locations from the manual and wrote on it:
ry%3D400
Remove the front end slider (shield) to gain access to the front mounts.
View from below:
ry%3D400
Loosen all body bolts (18 mm). Pick a side (I started on the drivers side) and start at the front and remove the bolt.
There are 12 body mounts on the H3. Two under the radiator, two right below the bottom of the front fender, four under the rocker panels, two in the top of the wheel arches of the frame and two behind the bumper caps (accessible from under the truck).
Remove the bushing and place the bolt in a vise upside down. Using a hammer, drive the bolt out of the bushing washer.
A couple of good hits are needed:
ry%3D400
Place a new bolt and supplied small washer through the bushing washer.
On the front mounts, there was very little body to jack up. Take your time raising the front in order not to damage anything. Slide the spacer in between the body and the bushing. Place the supplied loctite on the threads. Insert the bolt and finger tighten. Work your way down the side and then come back to the front and start on the other side.
This is a shot of the front mount behind the bumper:
ry%3D400
View of the drivers side front mount below the back of the front fender:
ry%3D400
Check all of your body to frame aliment measurements. Adjust if necessary. Per instructions, torque all of the bolts down (22 mm) to 75ftlbs (manual for a 2006 said 85ftlbs).
View of the drivers side from mount below the back of the front fender and the amount of lift achieved:
ry%3D400
I have an AirDoc's intake installed, so there was no trimming of any covers
I found that I needed to bend the heater hose bracket that attaches to the engine upwards and a small upward bend of the passengers side front brake line was needed. The power harness on the drivers side rerouted it's self slightly during the process.
The rear body gap is not noticeable to me:
ry%3D400
I'm was not happy with the front gap, especially at the corners. A Thor bumper upgrade solved that issue:
ry%3D400
ry%3D400
ry%3D400
Over all I am happy with the upgrade. It took me about three hours by myself to do it. I believe I could have cut that time in half had I had a better jack and had I not had to figure out the fan shroud.
Great thread. Thank you 58Bisc. After seeing this thread and Reloader's, I've decided that I need to do this to my T! thanks again for the detailed info. & pics!
Reloader
Montana a free state
The fan shroud in an I5 is much easier to deal with, thats for sure.Yours went pretty much like mine did. I did mine on the hoist and used an under hoist tall screw jack to lift the cab.I lifted the whole side at once and slid in all 6 blocks at once. I didnt use any thread locker as those body bolts are hard enough to remove due to rust belt corrosion. Plus Ill check them every time I service the vehicle. You have a good looking rig with the Thor setup and the red color. I think the back looks better with the extra clearance under the rear door and the space under the spare now. Plastic dip your wheels next.
Sennin
South Africa
Excellent writeup, thanks
A quick Q for the people that know, does the same apply to the fan shrout on the V8? if there is, how do you mitigate the body lift on the V8?
cbetts
NERD!!!
Rancho Palos Verdes, CA
Thanks for the write-up! I was a little lazy and forgot to document when Mudbug helped me install my kit. I am pulling the grill off of mine to install the OEM off road lights in the lower grill and was thinking about putting in a wider rubber strip to block that gap in the front. My brush guard hides most of it but the area under the marker lights look terrible.
humvee
Doha, Qatar
This is the only thing I'm worried about, any luck finding a wider strip?
I would appreciate if someone could tell me where to buy these online.
