IndyHummers
- Murfreesboro, TN
Yup, and then the next morning the H3 didn't start lol.
The capacity for the rear is 2.5 quarts. I just changed mine a few weeks ago
Rotate the cover to make the existing "fill" port a drain port, then put the new fill port at the proper level.
You have a drain on the diff anyway in the event you choose not to pull the cover.
Yeah I saw that on the bottom. I am just the kind of person that if for whatever reason I need to drain the oil, it would be a good time to inspect the gears too.
And I probably won't ever mess with that drain on the bottom of the case because my luck it would come loose and fall out after. I spent most of the day working on my new fill plug bung.
The typical reason for draining the diff lube is to change it at the service interval. Hence the drain plug.
Do you worry about your engine oil drain plug falling out?
Right, but also, having no oil in the axle, wouldn't it be a great time to pull the cover and visually inspect the differential? Especially on my vehicle whereas I wheel it offroad, not just on-road driving.
I don't have a gauge on my dash to tell me when I don't have oil in my rear axle and to immediately stop driving...
and fwiw my brother's plug fell out 40 mi. after an oil change from Jiffy Lube. Just saying it can happen.
