jryanantczak
- Denver, Co
have a 2008 H3 Base L5 and am experiencing issues with the right tail lamp assembly. The tail lamps and backup lamps work normally on both sides works, but the turn signal and brake lamp on the right side do not. Left tail lamp assembly works normally in all functions (tail lamp, brake lamp, turn signal). The bulbs have been replaced, as has the pigtail connector wiring harness connector for the tail lamp. I've traced the wiring harness up the passenger side of the vehicle back to the BCM and there is no visible damage, pinching, exposed wiring, or shorts to ground.
I have swapped out the multi-function assembly on the steering column with an OEM unit. I have gone through the fusebox under the hood with a fine tooth comb, verifying that each and every fuse is intact.
I've even gone so far as to "jump" the wiring from the left lamp to supply the right lamp assembly. I am able to get brake lights then, but the brake lights then stay on until I disconnect the battery from the vehicle, so this clearly will not be a permanent solution. I've also tried running a dedicated wire from the front right turn signal to the right rear tail lamp assembly, but cannot get the turn signal to function still.
The whole thing began when I noticed the "fast flashing" turn signal arrow on my instrument cluster, which 99% of the time is simply a blown bulb.
HELP PLEASE!!!
HELP PLEASE!!!
