Alpha X
- The Motor City
In another thread I inquired changing the ball joint in the H3 Upper Control Arms. Looks like it's not really possible.
Upper Control Arm - Ball Joint?
https://www.hummer4x4offroad.com/forum/showthread.php/13674-Upper-Control-Arm-Ball-Joint
Let's assume, for a moment, you could make a totally new UCA for your H3. It has to be a bolt on solution, no welding on new frame brackets, etc.
What would you revise/change/improve?
1) Different Ball Joint? Silverado style, or something else that can also be rebuilt/replaced? (let's assume we can change the knuckle to accommodate a new style ball joint)
2) Would you retain or change the cam style adjustment where it mounts to chassis? Or, is there a better way to get some adjustability?
3) Cast and/or machined aluminum or fabricated/welded steel?
4) Anything else?
4) Anything else?
